Luis Redinha
Everything posted by Luis Redinha
  1. Hi, Got the same problem a couple of months ago. You have to buy the all thing, not just the cover and it´s a easy DIY job. There´s a lot of parts supliers from UK ( do a goole search ) and they will ship it to you . Csot was around 60 Euros Luis
  2. Hi I need to replace the headlight washer cover and jet nozzle on my 2003 C2. Is it a simple DIY or should i book the car in shop? I already ordered the parts from Porsche Parts Thanks Luis Redinha
  3. Hi, Bridgestone S02 (great tires. Be carefully not to mount "S02A") Why??? Thanks Luis
  4. I´m sorry but can´t you use one of those foam cans that will seal the inner of the tire. It´s readly available here in Portugal at every Gas station and if needed afterwards you can always have the tyre taken out of the rim, washed and the puncture repaired Luis
  5. Hi I was driving in the speedway, steady 150 kmh, when sudently the warning message - oil pressure indicator failure popped in the OBC and the needle droped to zero . No other signs or noises and after restrart everything went back to normal and I drove another 450 km without problem. Should I be concerned or it may have been only a glitch? Thanks
  6. Hi there Remover the cover and look for rubbing of the seat belt against the isolation foam inside the pannel Luis
  7. This site is unbelivable and you guys are top notch. I have a 2003 C2 and it does exactly what is described at around 2800 to 3000 rpm. I also have a Cooper S that has the ame behavior but at higher rpm´s Thanks Luis
  8. Hi I have 2 kids ( 6 and 5 ) and both setas fit in the back seats of my 03 C2. The seats are made by ROMER in Germany Luis
