Canuck23
Everything posted by Canuck23
  1. I will double check it and thanks for the speedy reply. Cheers
  2. Hi New to this old forum but was wondering if anyone has had to re-wire a headlight assembly as my turn signal will not work. 2002 Boxster S Bulb is good and a new relay flasher and I have powered up the headlight assembly out of the car and everything works except the turn signal. The socket is good and I believe there is either a bad connection or a shorted wire inside the assembly. Has anyone run into this before? Thanks for your input.
