Francisco Contreras Garcia
Francisco Contreras Garcia's Achievements
  1. Thank you very much JFP in PA for your quick answer. I took the Panamera to change the oil of the PDK gearbox at a specialized automatic transmission workshop in the country where I live, Spain. Regarding your previous post, they only changed the FFL-3 oil for the gearbox and clutch plus the filter. As you can see in the invoice below, 7DT70 (O7DT765A42028) and the one you mention in your post is 7DT75, maybe that is the reason?I am not a professional and I do not work in mechanics, I am just a Panamera user which I love. They used a PIWIS unit after replacing the oil and filter. The told me that no code or abnormality was found. They did not change the oil for the final drive. Could this be the reason why I am experiencing problems (the same rattle noise as bcmac) in the 5th and 7th gear? Thank you very much for your unquestionable and invaluable help in my quest to keep my Panamera running trouble free. I forward invoice (Gearbox Filter 7DT70 (O7DT765A42028) + 10 litres FFL3 oil) Video.MOV
  2. Hello Bcmac and JFP in PA, I have a 2013 Panamera (3.6L) and I am experiencing exactly the same symptoms you mentioned. After taking it to change the oil of the PDK gearbox, I have the same problems in the 5th and 7th gears. I am a bit puzzled and don’t know what could be wrong. I am not sure whether to complain to the place where I had the PDK gearbox oil changed or to take it to another workshop to have the PDK gearbox checked directly. How did you solve your problem? Is there a solution? Is it worth it considering that PDK gearbox repairs are very expensive? Thank you, I really appreciate yours comments/suggestions...
