ZDLT4
    Orlando, FL
    2004 996 Cab, 2001 S2K, 2023 F150, 2015 Jetta SEL, 1996 Wrangler Sport, 2023 Bronco
    1996 Corvette LT4, 2018 718 Vert
ZDLT4's Achievements
  1. Fluid level checked and serviced, no big leaks noted. I have the carpet out and have looked at all the components I swapped out the top module with another one today, still can't get it to calibrate or talk to module well. The scanner will tell me other info from Engine, Airbag, etc. I know its out of synch now for sure when new module and symptoms remain the same. Do you have a pic of how the top is supposed to lay flat in the rear storage? I feel like mine is about two inches shot of where it should be. Swapped out the top module - No improvement. Tried to run a calibration using Durametric and got the same results. I am running out of ideas. Any ideas of good places to take it near North Orlando area?
  2. I attempted to use a Durametric scanner to calibrate the top and it wouldn't do anything. Said the command was sent but nothing happened. The pointer just circled around and around as if it were thinking... If top is partially down, it will go up normally and complete the cycle as it should. When I try to retract it, it hangs up just before the deck lid and side flaps move back into position. How does one determine if the module is bad?
  3. Recently purchased a 2004 Cab. Top closes fine and windows roll up. When trying to lower, it seems to hang up throughout the process. Press the top button again and goes a little further. It won't go past the top laying flat. Deck doesn't come foward and flaps don't come up. Attached Duramatic and attempted to calibrate, it didn't do anything when selected. Could my module have issues? How do you test?
