ninetynine996
Everything posted by ninetynine996
  1. Hey everyone, I'm nearly done wrapping up a cooling system refresh on my MY99 C2. I opted for the genuine Porsche 996.2 coolant tank. I'm having an issue getting a snug fit for the coolant tank sensor. I went with a unit from Hamburg technic. It seems possible to only slot the sensor in one direction. Once it's seated it's not possible to spin it in order to lock it into place. Am I running into an issue with the aftermarket sensor spec? Short clip of my issue below. Thanks in advance!
  2. Thanks Loren - it definitely was P1689. Adding a screenshot below. I ended up swapping out the ecu relay (behind the rear seats) for a fresh one, reset the codes and it hasn't come back yet. Hoping that did it! `
  3. Hey everyone, first post here and fairly new owner of a 99 C2. I've finally been able to run some diagnostics with the Durametric and I got the following fault codes: P1689 - Control unit faulty P1531 - Camshaft adjustment bank 1 I suspect P1531 is a result of a faulty DME, but that is simply a guess. I should note that I've had issues connecting to Durametric and seeing the fault codes in the past (evidence of some kind of DME issue?) Also, I've been experiencing a bit of hunting idle and what feels like engine shuddering (misfires?) at idle. I've cleaned the MAF, TB, and replaced the IACV. The vehicle had an aftermarket radio installed by the PO which I've recently upgraded to a double din unit, but I haven't changed any of the wiring. I'm in need of some troubleshooting help. Would it be worthwhile to start with a replacement of the DME relay? Thanks all! dro
