CMcK
Everything posted by CMcK
  1. I've just purchased the Solisto Extra and I can confirm it works with my iPhone 3G. You get the usual message about the peripheral not being made for the iPhone and the offer to switch the Airplane mode on. Also the iPhone doesn't charge via the Solisto unit.
  2. I've just bought the Solisto Extra adaptor. Fitting was very easy. I removed the CD changer and the bracket to expose the cables and wired up the Solisto supplied cable. The kit included a cable for my iPod and once it was plugged in that was it. I need to fashion a bracket or something similar to hold the iPod and Solisto Extra in place though. The Solisto adaptor works as advertised. The CD 1 to 5 buttons on the PCM correspond to playlists titled CD1 - CD5 on the iPod and CD 6 on the PCM is a direct access mode which leaves the iPod in control. You also have the option of just having 6 playlists as well. Each playlist can be up to 99 tracks long. Shuffle works on both modes of playback but the skip track buttons only work with playlists. Although curiously the fast forward/review functions seem to work on the direct access mode. The iPod charges while connected as well. Sound quality is excellent. To my ears it sounds better than the old 6 disc changer.
  3. All the sounds I have described have been while sitting in the car. The vents I am referring to are on the dashboard. From what you say it sounds as if I have more than one problem. I will have a bit more time this weekend to play around and see if I can pinpoint where and when the noises occur.
  4. Thanks for your help. I can hear the whining sound most of the time while the air con is running not just when the air con clutch is engaging. The high pitch sound from the vents is seemingly random, I haven't been able to make a connection with any other event such as accelerating or braking. The car is going in for a service soon so I'll make sure all the belts and associated pumps etc are all checked out.
  5. The air con in my 02 986S (UK model) has started making some peculiar sounds. There is a whine from the center/rear of the passenger compatrment. And there is also an intermittent sound from the vents. The sound is like that of the fans blowing normally but louder and higher pitched. The air con is still blowing cold air OK and I have already had the condensors replaced 2 years ago and there was a leak in the suction pipe beneath the drivers door which was fixed a few months back. Personally I suspect a problem with compressor but I dread to think how much that'll cost to repair!
  6. I've just noticed that both lights are flashing on the CD-ROM drive for the PCM1 unit in my 2002 986S. Anyone know what fault this is indicating? The disc will not eject and the navigation system is stuck on the initializing screen.
  7. I bought a 2004 Opel NCDR from Ebay but I was sold a backup and it did not update my sat nav. The system was trying to initalize and you hear a lot of seeking sounds from the CD drive. I assume there is some kind of copy protection on the original disc?
