WTL
Everything posted by WTL
  1. so once the foam stops coming out, the vents work the way they should? i.e., the air will not come from the defrost when its not selected......
  2. so I have air coming from the windshield vent when the ac is on and have vents footwell and dash only selected...... Could this be caused by this foam deterioration issue you think?
  3. so just out of curiosity, I have a 997_1. I was at the dealer the other day looking at the new models and mentioned this foam issue. they said they have seen this issue, but that the problem is not with the blending doors, rather from foam that might have been "pinched" together when joining together pieces of the duct work. or, if I understood them correctly, where a connector piece is used and the backside of the foam degrades off. they say it is these little pieces of pinched foam inside the dust work that is finally degrading and blowing through. any thoughts? ive had foam blow out, not massive amounts, just curious as I've never had or seen the ducts/inside personally. tks air still blowing cold. sorry to post it here, but didn't see applicable post in the other side.
  4. having this issue too. where the heck are those flaps???
  5. not normal. something loose or shot. could be motor or strut....
  6. out of curiosity, do you have to have the phone module for this to work? Ive often wondered about upgrading even though i don't use the car enough to justify it, but i don't have the phone module. tks!
  7. Recently replaced my rear tuning forks bc of a noise at times when going over bumps. Car has actually been making that noise for some time now and have been putting up with it. Actually glad it's now gone. Question - out of curiosity - can the tuning forks be re-used ? Don't think I ever would but was curious if they could be refurbished?
  8. right o. if i had the tool and the time and the part, i would have too. but, wanted to try and get in on the de this weekend and didn't have time to look for the part, the equipment and the lift. maybe next time.
  9. right o. if i had the tool and the time and the part, i would have too. but, wanted to try and get in on the de this weekend and didn't have time to look for the part, the equipment and the lift. maybe next time.
  10. well, it was the water pump. yikes! expensive at the dealer!!! getting it done today.
  11. Doesn't have a particular odor that I can tell. Kinda slippery - more so than when I rub some of the antifreeze between my fingers. 40,000 miles on water pump. Getting close to my annual oil change too....
  12. But the fluid is not coming from there ? Ideas as to where or what it is ? Tks!!
  13. can someone tell what this might be? went for a short drive today and noticed a little puddle on the garage floor after i got back. no previous staining on the floor, so it must have started while i was driving or after i got back. stuck a piece of cardboard under the engine area to figure out if i can tell the rate of the leak. any ideas what it might be? Tks !!
  14. got it. tks! will try again to find disassembly instructions for door panel. the only problem after that is that i have no real electrical experience in testing switches - so this may be a problem.....
  15. got it. so for the door micro switch, would that be the switch that activates the window or something in the window regulator or with the window motor?
  16. Just to confirm - roof latch micro switch may be causing passenger side only auto up/down interference? Is MIL for master indicator light? Tks
  17. So maybe some one with technical expertise can see a connection here - passenger side auto up has still been not working. Just tried the 10sec reprogram again the other day with no success. Gave up again as I never found a diagram to access the window motor or window regulator. Any tips for those, please?? Havent put the top down in a long time - first time tonight in a awhile. So go out for a snow ball with the wife, pull into the garage and make a wish that the switch works. Put the roof up and the wife says, not again and goes to get out as I try the driver's switch for the passenger window. Auto up and auto down worked. I then tried the passenger switch and auto up and auto down worked. So so any connection with putting the top down and auto up/down now working? What would be the connection if any? Tks for any help.
  18. i guess this is what's next.... i'll check this out once i find some detailed instructions and description of what i need to look for / at. Tks for the tip Loren. Seems unlikely to me that both passenger switched go out at once.
  19. the dealer tried to reset the one touch with no luck. no error codes according to piwis and driver side one touch works. so unless somehow there is a setting that deactivated the one touch for the passenger side only, and they mentioned nothing about that, i'm guessing it may be the motor as that seems to be the common denominator between both passenger switches one touch up not working. right? i'm tempted to take a look at the window motor, but wouldn't know what to look for, baring any frayed wires or obvious signs. any tips? I did email with a parts supplier mentioned here on the site and they had a hard time understanding what the problem is and basically told me to start swapping bad parts with good ones????
  20. interesting because I quote from the manual :- One-touch operation Press the rocker switch upwards or downwards to the second stage. Window moves to its final position. Press again to stop the window in the desired position. One-touch operation for closing the passenger’s window is available once the window is approximately half-way closed. That is the way mine works too, hence my comment! so i thought i'd check my manual just for the fun of it... " press the rocker switch upwards or downwards to the second stage. window moves to its final position. press again to stop the window in the desired position" my manual doesn't have the part about half way closed. page 28...
  21. yep, both windows up and down is how it's been for me. still trying to figure out the passenger side though - won't one touch up any more, just down. maybe i will have to buy the motor?? don't know what else to try. anyone have any ideas? Loren, tks again for the reset procedure - i wish it had worked :cursing:
  22. Neither switch would take. Auto up does not work for passenger window. Driver side works fine both ways, but passenger side no good.
  23. Car just on or started? Driver side switch or passenger side switch? Tks
  24. so my passenger window will not one touch auto up from the driver side window switch or the passenger side switch. the auto down works fine for both switches for the passenger window. does anyone know the correct procedure for me to try and reset it? i did a search, but can't find anything. the dealer says i need part 99762418206 at 632.00 plus 330.00 for labor, but id like to try the reset 1st myself. they said they tried and even tried something with hooking it to the computer with no luck. tks!
