arlanbart
Everything posted by arlanbart
  1. The gas pedal on my 2000 Boxster S is kind of sticky instead of smooth. I'm sure a little lube in the right place would fix the problem. Has anyone encountered this? If so, how do I remove the pedal or where should I lube? Thanks.
  2. The gas pedal on my 2000 Boxster S is not smooth. It's a little sticky and probably just needs some lubricant at the right spot. I've seen 2 other people mention the same problem on their 2000 Boxster S's. Does anyone know how to remove the pedal or where I should try some lubricant? Thanks a ton, guys.
