teamnicole
Everything posted by teamnicole
  1. Sorry to keep being so difficult! I read the article about replacing the cables with the newer reinforced ones. After reading it I went out to my car and checked and they actually do have the texture of the reinforced ones, like the diamond pattern. That being said, could it still be a cable problem? I just don't want to try and take it somewhere to get looked at because I ALWAYS get ripped off!! :soapbox:
  2. Thank you guys for your help, I really appreciate the info so far. It was really frustrating me today so I went and took off the vinyl cover to reveal where the noise was coming from. I'm assuming that the black box in the first picture is the motor for the top? Well when I push the "open" button to put the top down, the cables coming out of the driver side of the box (the one where the green line is attached) move up and down and that is where the ticking is coming from. The single cable coming out of the passenger side doesnt seem to make any noise or movement. I tried moving the cables around to where ever they attach at the motor and they move around a bit but still nothing worked. Sooo - I guess I will try and do the cable thing myself, if that's what everyone thinks it is after this post. Thanks again for any info you may have!
  3. Hi guys, I am a new member to the forum but not new to reading all the great info you guys post. I have read through sooooo many pages on here but my top problem is a little different. I've only had my 98 boxster for a couple months now and the top was working good. Sometimes when putting it up, it wouldn't align perfectly but it would still fit itself in there. Anyway after weeks of bad weather and tons of rain, I attempted to drop the top today and nothing :( The only thing is that, after I unhook the top latch and press the "down" button. The motor starts going but it's making a repeat ticking sound. The top doesnt budge at all and nothing moves. I checked to make sure the hand brake was all the way up and that the "brake" light is ignited on the dash - it is. My windows roll down half way and everything. Ive even tried pusing the microswitch in and out a few times while trying to retract the top and still nada. I just don't get why the motor would come on, everyone else says it's like their motor is dead. Also--- not sure if this has anything to do with it but sometimes when I flip the ignition and start the car - if I attempt to turn the headlights on - as normal, only very dim lights will appear - not enough to see with at night! And also, when this happens I realized that my heat/airconditioning won't turn on. The display will be illuminated but when I push the buttons for any air or heat to come on - it will say on the display that it is coming on, but nothing blows out, so I have to turn the car off and back on and that usually does the trick - the headlights will be back to normal, nice and bright and the heat/air works! What the heck is going on? I've already spent quite a bit on other repairs for this car and I really wasn't planning on spending a whole lot more :( Please help! Thanks in advance, amanda
