tolum
Everything posted by tolum
  1. Thanks Loren but my latch looks like the last picture. One spring end is in a hole, the other on the latch BUT the spring is not under tension when latch is at open state. Normal?
  2. Hi, 2003, 2.7 Boxster. I own my Boxster since 2008. Since then, when trigging the hood openning knob, the hood only rise by 1/4 of an inch. Is that normal? I was thinking that it would rise higher. I did unbolt the lower latch, unsnap alarm/light module and look to the riser spring. It looks to be in place. In the open state, the spring is a little loose but when I put the latch in the close state, the spring is under tension. When releasing it, it rise violently. There are white litium grease in it and no rust. Playing with the rubber height adjustement on both side of the hood doesn't help. Before spending $155.00 on a new lower latch, I would like to know if it is probably the problem? Also, any body can confirm how high the hood should rise before releasing it manually with the red manual latch and open it all the way? Thanks you all and have great and safe holliday weekend Canada & USA. Thierry :help:
  3. No problem. Now enjoy the REAL PURE sound of your Boxster... Mine is now winterised. Will start it again in May. Thierry
  4. Nop! Still have that annoying problem but for now, my Boxster is winterised. I will start to think about that next April but will look to that topic often in case yourself or somebody else find the solution... Thierry
  5. Hi; Just did my brake/clutch fluid bleeding process. Simple to do, economic too! Any body can confirm how they clean it so it works like new in 2 years? Thanks! Thierry
  6. Ok, finally got the second part and it works! Noise is finally gone! That one was the broken one. So if you look to the drawing I did post above, the first electric valve I did change was item #6 that goes in the valve housing item #8. It wasn't the problem. So I decide to order the second valve that goes in that valve housing, item #9 that is P/N 996.605.213.01 and that time it was the right one. So your problem is maybe related to item #6 or item #9 or both. I paid $46.13 at Sunset Imports (Jeff). Accessing that valve housing is done by 1- Removing passenger front wheel and plastic well. Valve housing will be at top right of the wheel well just behind the front headlight. The housing is bolted up there, so unbolt it. The best way to access and remove the valves from the housing is done by going by the front headlight that you have to remove first. Use a flash light and you will see the valve housing that you just unbolt.. Inplug power from the valves (both terminals are different, you can't mix them. There is a plastic sleeve that cover the valves. Use a Torx screw driver to remove it. Pry gently the valve metalllic ring and voilà! :thumbup: See att. picture of the broken valve.
  7. Thanks Loren. Tomorrow is oil change day. Thierry
  8. Sorry, wrong number, I got 996.107.225.60 Thierry
  9. Hi, 2003 Boxster 2.7. Just order and got an oil filter from Suncoast. First time I get that part number: 996.107.225.50 Is this compatible to my car? Thanks! Thierry
  10. On my side, that noise stops when I put a piece of duct tape on the vent inside the fuel filler section at 3 O'clock when looking in it. Still waiting for a part to make a try. If it works you will know it. Thierry
  11. Did change that valve. No change, noise still there. I will order the second one that is just nect to that one and see. Should get the valve in few days. Will keep you posted. Thierry
  12. Remove the front right wheel. Remove the plastic liner in the wheel section and look up. You should see the fuel tube that is aluminum color and the back of the fuel port and valves. Thierry
  13. Update: I have ordered Shut Off Valve P/N 99660520101 @ $70.54 from Sunset Imports (Jeff). I will install it end of July when back from holidays. I'll let you know the result. See att. drawing... Thierry
  14. Did some search on the net. By what I found, many Boxster owners have or had that problem. The most precise answer I got, but still not sure at 100% if it was the culprit is a part from the fuel system named Valve housing P/N 996.201.231.01 but as I said, I'm not 100% sure, so maybe some body else can confirm that??? Thierry
  15. I have the same strange noise that sounds like a train horn between 30-50 mph on my 2003 Boxster 2.7. I will follow your thread
  16. This is my final update. I did it! That check valve was out of his plug and it was a source of two problems: 1- Repetitive CEL P0171 & P0172 and 2-Short hiccup when pushing on gas at low RPM. I'm so happy! My car is now like new! Thierry :notworthy:
  17. Ok, I found where that backflow goes. it is in the right rubber sleave that att. the throttle body to the right intake plenum. There is a hole there to plug the output of that black/white valve. So Loren, I guess, that's the source of my leak! What do you think? I'll reset my CEL and see the result. Thanks for the help. Thierry
  18. Ok, did look into the engine section for a leak search and found a white&black round part that have two small hoses going in by a "Y" but the ouput of the part in not plugged. Normal or no? Please look at att. picture. Thierry
  19. Other that piping from the MAF and throttle body, where do i have to check for a leak?
  20. Hi; My car is a 03 Boxster 2.7 (56000 miles) I have a Durametric cable. Since two months I'm having CEL. The fist time the CEL show up, I had P0171 and P0300 series. P0300 is ok now because I changed all 6 ignition coils that were lightly cracked. This morning, P0171 shows up again and a new one, P0174. I'd notice that everytime (3x) CEL shows up, it is when engine is warm and when I'm about to park the car and motor is at iddle. CEL never happen when on the road... At iddle, RPM is very steady, engine Rev fine and very smootly. I did check the entire intake piping from the MAF to the throttle body and from throttle body to motor intake. Everything is tight. So I'm out of idea. Any other think to check for or maybe a cure? Thanks. Thierry
  21. Mine is doing the same. When lowering fan speed to OFF, the click, click, click is there for about 10 seconds and it's gone after that... Thierry
  22. Hi; Boxster 2003, 2.7 I'm looking for P/N for the plastic screws that hold the foam cover that is att. under the glove box just above the passenger feets (See pictures). Thanks! Thierry
  23. Here you go: 2003-4 Boxster OBC: Plug C (Grey) on the Instrument Cluster Pin 23 - Stalk Connector Pin 2 Plug C (Grey) on the Instrument Cluster Pin 22 - Stalk Connector Pin 3 Plug C (Grey) on the Instrument Cluster Pin 21 - Stalk Connector Pin 4 Plug C (Grey) on the Instrument Cluster Pin 24 - Stalk Connector Pin 5 Plug C (Grey) on the Instrument Cluster Pin 25 - Stalk Connector Pin 6 Earth (ground) - Stalk Connector Pin 1 Good luck
  24. Thanks fot the advise Loren, I will look to my pulleys. An happy Boxster weekend to all! Thierry
  25. Will change my poly rib belt this weekend. I know that prior to remove the old one I have to put an arrow showing the belt rotation but for the new one, is there a specific rule to follow regarding the rotation or it doesn't matter as it is a new one? Thierry
