docdav
Everything posted by docdav
  1. Solved. Massaged the relays beside the fuses and voila ;-) Happy new year to everyone. Michael
  2. True friends. I have looked at pictures of the sender, it looks like it is pressed to the bottom by a spring, and there is a telescopic mecanism in the unit itself, There must be theoretical risk og the telescopic mecanism has got stucked in a high position and the foot of the unit is not at the bottom? Just a thought (and a easy check). But the above also makes sense. Thank you for responses. Michael
  3. Strange strange??? I normally fill up the tank when the light comes on. It takes max 32 liters and the manual says it should take about 60 liters. After having filled (with the 32 liters) the meter shows full tank. When driving nicely, the car goes about 10 km/l thats ok. Range on a full tank (untill the light comes on is about 290 km The tank seems too small.? Any suggestions? Its a C4 Kind regards Michael
  4. Solved the problem with a simple ground wire. The old radio was a not original, it was a navtech single din. The new one has apple CarPlay and I love it ;-) Kind regards. Michael
  5. Dear friends. I have just installed my new Pioneer SPH-DA120. Though I still need til connect the safety wire to the + wire of the parking brake switch. At what place should I look for it? What colourcode am I looking fore? Kind regards Michael
  6. Preferably when the car stands still. Any suggestions? Kind regards. Michael
  7. Done. Repair took 30 min. I did loosen the seat with the E12 Torx, but didn't unplug the wires due to risk of activating airbag lamp. THX for help. Michael
  8. No light in none of my lamps? No current? Fuse ok? Instruments lights ok (same fuse, as far as I know) Where to start? Any help will be appreciated. Greetings form Denmark Michael
  9. Just as you say. Thank you my friend. The former owner was a "big guy", I think the seat just gave up to his weight ;-) Kind regards. Michael
  10. The hight adjustment of my passenger seat does not work anymore. (Carrera 4 from 2001) The seat is locked in top position, the motor is humming both when pushing rocker up an down, but no movement? Motor sounds different from other seat motors. Is it a small compressor to pump up or how does it work? Alle other directions=ok Any help will be welcome. Regards Michael Davidsen
