chipper
    03 Porsche Cab
    02 Corvette
    06 MB c230
    02 Ford F150
chipper's Achievements
  1. Not for a MY03 and newer car - those would be CDR-23 radios with the MOST interface. The code is permanently kept in the DME so you only need to re-program the code if you change radios. The radio (factory) does nothing, like it has no power at all (no light, nothing). Would there be another fuse on the back of the radio or some other fuse that might prevent power to the radio? The radio worked fine until the car battery was disconnected.
  2. The battery was disconnected on my 03 996 cab while at the body shop (getting new front bumper). The radio will not power up after the battery was re-connected. I checked the fuse box and the radio fuse was ok, but the sound package fuse (row D, fuse 9) was blown. I replaced the fuse but still no power to the radio. Any idea what good be the problem?
  3. Thanks - I will give it a try.
  4. 03 cab. installed cab aero wing from precision porsche.
  5. Can someone advise me how to correctly wire a fixed wing to avoid getting the "Your wing did not raise" message when I exceed 75 mph? The message goes away when I turn off the car and only comes on when I exceed 75. I installed a fixed carrera wing (cab aero wing from Precision Porsche) and re-connected the fan. engine area light and wing 3rd brake light. The three wires that went to fully raised indicator (I think) are wired together. The other 3 wires were left alone. The new 3rd brake light works fine. The original light no longer comes on ( which I expect is what it should do now). Do I need a new wire harness or have the computer re-programed? 03 Cab
