tighttrailsaregood
    1990 911, 2008 Cayenne
tighttrailsaregood's Achievements
  1. Hello all, I have a set of tweeters and mid range drivers to install in a 2008 Cayenne (aftermarket amp and head unit). The mid drivers in the doors were easy, but I need to get underneath the existing tweeters in the dash to modify the mounts. The very front plastic cover (the part that goes right up to the windshield) seems to be one piece with the upper dash - does anyone have instructions on how to remove the cover to get to the underside of the oem tweeter mounts ? Thanks much !
  2. I have the H&R kit and 15mm spacers installed on a 2008 V6 for about a month now, and the car handles significantly better than before in turns. Apart from less body roll and a very planted feeling you can drift the car through turns nicely now :-) Optically the kit is a big improvement as the wheel wells now align correctly with the tire outline. Installation is more like $500,- with alignment and corner balancing.
  3. Hello, has anybody retrofitted the Tequipment ski bag into a cayenne ? If so, how did the installation go ? Thanks !
