Louis
Everything posted by Louis
  1. Dear All, Just to let everyone know that it was the Voltage Regulator unit attached to the Alternator that was not working propoerly.. but the Alternator was passing all the tests... I have change the Alternator and now the issue is resolved.
  2. Hi Kurt, Can you send me a picture or a more detail info about the location of the seat belt warning module in the trunk area? I would really appreciate.
  3. I have someone who told me it could be my voltage regulator? do you know where it is located?
  4. Hi Loren, i forget to add that when this occire i also have the following symptoms: while it does this i have also the dashbaord lighting that goes up then back down.
  5. Hi Loren, this is a US porsche, which relay are you talking about? where shall i found it? i have already replace all the fuse, took the radio or as well as the amp to see it was the cause of the matter.
  6. On a 911 carrera Coupe 1987 Has anyone had this problem? Every time I stop at a light or stop sign, upon accelerating from a stop the fasten seat belt warning lights up for a few seconds. Sometimes (especially at night) it gets to be annoying.
  7. Thank you for your answer but can you be a little more explicative? what do you mean by loose fan belt?
  8. HI All, I have a 911 carrera 1987, and i have an electrical issue, which is the following, when i tend to accelerate i have the fasten seat belt light that turn on, and also the light of the dashboard tend to dime. As per what i have understand it look like there is a short somewhere? Thank you fo ryour feebback
