vecchiae
Everything posted by vecchiae
  1. I got it to work, thanks to those that tried to help. When I started my test the PCM refused to read the disc and didn't eject it either, thus I did more tests with the CD changer. I didn't know that the changer doesn't read mp3. Thus I started doing tests with the PCM again, the key to get it work was to finalize the disc.
  2. The car is a 2007 MY, purchased new, thus it should have MP3 and the car manual says it has Mp3 CDC. Those that managed to burn MP3 files, which software did you use to burn the CD ?
  3. I have a 2007 997 with CD changer. I can play audio CD (including some I burned with ROXIO or Microsoft Media Player) in the CD changer, but I have been unable to play any data CDs with many MP3 files. I want to record about 50/70 songs in a (data) CD, rather than the usual 12 songs you can burn in an audio CD. I am fairly computer literate and I can use most CD recording software. I have attempted various recordings of data CD, recording with Disc at Once, track at once, I finalize the CD , used different mode and file system, to no avail. The CD charger does not recognize the CD at all. The single CD player not only does not recognize the CD but also refuses to eject it, as if it doesn't exists (I got it out anyway with a hard reset). The various software versions are as follows: SW version 4.0 CDC C38/3003 AMP 00017600/3105 SYSTEM 05462AD1/4605 PCM 05395BD1/4505 I assume that the software versions are pretty much up to date, but I appreciate if somebody thinks the problem is the software version I have Can somebody share the specific CD recording options they have used to burn a CD containing a large number of MP3 files?
