madalin29
Everything posted by madalin29
  1. HI Loren, what i intent to do is replace the speakers, mount a OEM rear view camera and also install a remote start system (based on Viper 791 alarm system). for all this, i need to make "some adjustments" to my car wiring harness... and here i'm stuck :D
  2. Hi ! Does anyone have wiring diagram for a 05 Cayenne (V6) ? i'm interesting in particularly on brake pedal switch, pcm 2.1, speakers (sound system), parking aid system and rear view camera... or anything regarding wiring diagram for cayenne. Thank you in advance
  3. Hi yes i've managed to install bluetooth adapter on my dension 500. it's very easy to install... anyway you have to put an extra wire from bluetooth module to pcm (if you have one) on the mute pin. doing this you are able to see "EXTERNAL PHONE" splash screen if someone is calling you. the only problem is... the module is not 100% functional... i mean a few times it's disconnecting by himself and also you have to change the source to CD Changer every time you want to use bluetooth phone. otherwise everything seems to be ok. Ohh by the way the module came with a VERY GOOD MIC !!!! install it on the roof (behind doom lights), i guaranty it will work very well. Cheers
