leg911
Everything posted by leg911
  1. Curious if anyone knows if these two lines can be replaced / accessed through the right rear fender area? If not, then will I be able to achieve this by removing the AC? I need to replace these two hard lines that connect hoses to the lines that run along the bottom of the car up to the rack & pinion. I unfortunately went plowing in my car and something caught the two lines and mangled them. Any suggestion is appreciated in advance. 5&6 in attachment Larry
  2. RFM, Thanks for responding. Just to confirm you don't see the "year" being an issue as long as I have the same manufacture? If mine is a 1999 ZF and I buy and install a 2003 ZF I should be good to go? I am just confirming before I go spend $$$. Thanks Larry
  3. I would also ask if a transmission from a 986 would work ?
  4. I have a 99 Carrera Cpe C2 Tiptronic. I plan on buying a used transmission and having it installed. Can anyone tell me what years I could install a used one from without any major issues? 996 were manufactured from 98-05. I believe the transmission part number for a tiptronic changed over the years but that may not tell me if a later version will or will not fit. at this point in time I am focused on a used one from a 03. Please share any additional insight you might have that would help during the exchange. Any help / insight is greatly appreciated. Larry
  5. Curious how this issue was resolved ?
