porschewash
Everything posted by porschewash
  1. Topic cancelled.
  2. OE, ra Thanks for the response and I have (since sending my note) essentially stumbled into following the same steps you have suggested. As a result, I have removed the alarm/sunsensor plate after removing the 2 torx screws, but am still having a tough time routing the GPS antenna cable to the dash TP location. I have also "popped" the defrost vent on the drivers side close to the GPS antenna mounting location as you suggested hoping that would make the GPS cable routing easier but still have not been sucessful with getting the cable routed to radio location. I am using a soft wire for trying to find a routing path as you suggested with no luck. Now that you have confirmed I am on the right path I will continue with this approach. It appears my 02 C4S coupe is a bit more difficult than the the cab installation as all the service bulletins I have read only reference boxer installations. Oh well, no one said this would be easy!! Thanks again for your help!! coat hanger wire is pretty stiff, and you need to be able to jam it down behind the defroster ducts. I would assume that you have the radio and the A/C controls out so you have a big hole to work with. Just push the coat hanger guide wire down through the hole under the sunsensor plate and look for it below. It will tend to want to go behind the defroster duct work, which is ok because you can get at it from a little lower down. Once you see it below, tape the GPS antenna cable to the topside wire, and pull it through. It is a tight fit, but you can pull it through. OE, Thanks for your advise and I had the ATC control out as well as everything else but the fresh air dash vents ( above the ATC controls). WHen I removed that, the routing is really easy as you can see the opening by the GPS mounting plate. Installation complete and the functionality of the Traffic Pro is really slick for a single DIN GPS and the clean lines of my dash are maintained. Thanks for your help as well as BigSquid and first DYI project completed for me!! :thumbup: I'm installing a Sirius satellite antenna in that location and I'm having a heck of a time routing the cable. Any other suggestions besides what has been posted? How do you remove you fresh air dash vents? I believe if I remove the vents, I should have better access as well. Thanks, PorscheWash
