rollafson
Everything posted by rollafson
  1. Problem found (by someone more competent than me!) to be a split bellows hose - probably due to the cold weather and the fact that the car is 7 years old. Hope this helps. br
  2. Hi, I did make an attempt but the limited engine access makes for finding air leaks rather difficult! I'm pretty sure that's what it is, as covering the air intake to the engine doesn't yield the change in engine note that I'd expect, and otherwise the car isn't missing. I know an excellent chap with a smoke machine, so that's what I shall try late this week. If you can wait a few days, then I'll update you. I'm expecting a vacuum hose to have perished somewhere with our freezing UK weather... br/David.
  3. Thanks Loren - amazing response. I'll start looking for leaks in the intake and exhausts, as I'm thinking they'll be the easiest to spot first. Then I guess the fuel pump is the next easiest. Injectors I'll address last. But what about the MAF sensor - it seems these are problematic generally? Any quick and easy test to elimate the MAF sensor, as it's a costly component to replace? Again, sincere thanks.
  4. Hi, My first post (and I did search before posting) - couldn't find anything specific to indicate the cause of a CEL with the following diagnostic codes: P1128 Upstream Heated O2 Sensors Swapped P1130 Lack of HO2S Switch – Adaptive Fuel at Limit Cleared CEL and sure enough after a few days it came back. When starting, it's taking noticably longer for the engine to catch. Not sure I should be driving this now for fear of doing damage to the cat or something... Can anyone advise a course of attack to identify and then fix this problem? Other posts indicate the air system, such as bellows etc, but some more precise pointers would be invaluable. Car is a UK 996 C4 / 2001. Has had big service three months back (filters, fluids, plugs etc). Many thanks in advance. DJR.
