emil77
Everything posted by emil77
  1. Hi mudman2,
    your link for Rear Luggage Compartment Side Panel removal was removed.
    could you please send me manual on Rear Luggage Compartment Side Panel.
    Regards,
    Emil77
  2. Hi Try this solution - http://www.dension.com/icelinkgateway500.php I suppose dension gateway 500 could be best solution of problem You can control Ipod from steering wheel all content and playlists are indicated on the screen of your PCM
  3. That was really easy. I disconnected a plug from "auto pulling" module with help of skilled craftsman , connected again - and it started to work! :)
  4. I did it. The original emblem fixed by adhesive tape. I removed emblem by using :)) expired credit card. It does not leave scratches. Good luck!
  5. Hi It is time to change oil. People in service tell me that I can use oil filter from previos model. I would like to order original filter for my model could you give part # for oil filter for Cayenne V6 model 2008 Regards Emil77
  6. Hi all Yesterday rear lid did not automatically pulled into the lock. After I have an error message on cluster each time I drive my car. Does anyone have idea how it could be fixed and what could be the reason of this malfunction. Regards, Emil77
  7. Hi There is one antenna socket and two analogous sockets on rear panel of PCM. Does anyone knows what are their purpose or have schematics of PCM rear panel? Emil77
  8. Dear Loren! probably PCM retrofit manual will help Ermil 77, at least fix trouble with buttons? Do you have this info on your site? Alex. The PCM retrofit installation instructions are in a TSB - and they are available here to Contributing Members. Hi I looked through the TSB on PCM installation. I found there a lot of useful information. According to TSB I connected A8 and C14 sockets on PCM connector. Now all buttons are working. Thanks Alex and Loren! :renntech:
  9. Does it means that my PCM will never work and the only chance is to purchase a PIWIS? The other problem is that buttons on PCM are inactive. Is it malfunction or this is also the matter of coding? regards Emil
  10. Hi Loren Can I program(code) PCM by using PST2. If yes, then how? I bought used PCM therefore dealer refused to program this device! (unbelievable :angry: ) Therefore I plan to find PST2 and try to reprogram PCM. regards Emil
  11. Does PST2 work properly with cayenne 08 models?
  12. OK ;) , I will never buy anything for my car from e-bay. I tried to save some money, but now I guess that was not the best way.
  13. So it is possible to swap out the CDR23 HU with a PCM2.1 monitor and not install the nav part? Merely need to have the dealer reprogram the PCM? Is the swap out plug N play in the back? yes, connectors on the back side are same as in CDR.
  14. Only if you can find a shop with a PIWIS tester. thanks Loren. If I will not be able to find shop with PIWIS, may I post PCM unit for reprogramming. Could you advise me anyone. Emil
  15. When you did the install, did you install the DVD nav unit as well, or just the head unit? Which unit, the PCM 2.1? I am thinking about doing the same thing, as I do not need Nav, and don't want to go through the hassle of retrofitting everything. Any info you have would be appreciated, pics, instructions, etc. My guess is that you need to go to your dealer and have him program the PCM to let it know there is no Nav unit. Yes I only installed a head unit PCM without nav module. Don't you know how to program PCM? My dealer a far from my place. Is there any other way of PCM activation than visiting the dealer. Emil
  16. Hi I replaced oem CD receiver by PCM head unit. Radio and CD changer is working properly, but PCM buttons do not work and after 3-5 sec error message appears on monitor ( no navigation, amplifier detected). Could you tell me how this message can be removed. Thank you all in advance.
