clvig
Everything posted by clvig
  1. hi will 997 turbo wheels and tires fit a 996 turbo my dealer said i will need spacers or the rear tires will rub on the in side any info would help thanks and happy new year
  2. Glad it turned out well for you - as I said only a few folks have had the intermediate plate/gasket leak. thanks Loren do you think the sweating that the dealer said is right they said that will get a little trans oil time to time around the transfere case thanks and happy thanks giving
  3. hi i got my car back they replaced the trans pan gasket and did a trans service they said that was the leak and the slight oil around the transfere case was just sweating do you think thats true i wiped it and drove about 60moles shifting hard and jacked it up and check it was dry just asking what you think thanks for any help
  4. thank you for all your help everyone i brought to dealer they feel just needs a new pan gasket thanks again
  5. thanks for help
  6. thank you, is it a known problem for the leak at the transfere case
  7. is that bad it dripped from the pan i cleaned it off its been 4 days and does not look wet but maybe some small seeping and at the transferecase is the same is it repairable
  8. hi i have a 2004 996tt tiptronic with 2015miles i notice some oil around the trans pan i belive it is atf also some seeping by the transfere case has anyone seen this before any advise would be great thanks
  9. Yes. Just run a wire from the fuse box to switch to relay in engine, or You can tap into the existing wiring below rear seat area. Search here or 6 speed for directions. You'll love it!!!! hi i tried searching i had no luck can you give a link to it thanks http://69.13.120.185/forums/showthread.php...ight=pse+bypass #12 good luck! ck TSB's for install of PSE with wiring diagram! thank you so much
  10. Yes. Just run a wire from the fuse box to switch to relay in engine, or You can tap into the existing wiring below rear seat area. Search here or 6 speed for directions. You'll love it!!!! hi i tried searching i had no luck can you give a link to it thanks
  11. I have a 05 997S Cab with Porsche sport exhaust option can I rewire it so the on / off works with out the dme kicking in when driving at low rpms, I would like to control it for quiet mode when I want . Thanks for any help.
