ajjankoski
Everything posted by ajjankoski
  1. thank you for the info
  2. what side is cylinder 4-6 on drivers side or pasenger side 2.5 boxster 1999
  3. ok thanks i apriciate it i gess im gunna go after that variocam solinoid i was hoping that wasent it thanks for all the ideas
  4. well i ohmd out the coil packs and i checked spark on that whole side and the plugs are beru or somthing like that, the conectors i toolk off and ohmed them out too and reconected them 2 times. the variocam is the onlything im not 100%sure about because i lack a good scanner that can show me adaptaion values. one question that is off the subject do ya know of a awsome scanner that is not horibly expensive that will tell me the values im looking for
  5. i already cleand throtle and the iac valve and i used a smoke machine to check for vacume leaks. thire are some code first i had p1128,p1130,p1126 and thats when i found a hose broken at the aos, after i fixed that the vehicle ran horible until it got warm then i rescanned it and found (p1316,p1317,p1318,p1319, p015) all pending i ran the car some more and found p0300,p0304, p0305, p0306 all current
  6. i have a 98 2.5 boxster and it runs horibly when its cold but as it warms up it runs much better ive been working on this problem for about a week now it throughs misfire codes on bank 4-6 but when its warm it doent realy have a problem except for lack of power at high rpm. ive replaced maf,checked plugs, plug conectors, coils, intake leaks, injector pulse, fuel psi/volume im stuck i dont know what to do please help
