jucarbon
Everything posted by jucarbon
  1. Anybody can recommend a good mechanic in the Miami South Florida Area? Thanks! Sent from my iPhone using Tapatalk
  2. Cayenne 2006 V6 lately the abs and psm light is on. Now I start the car and the speedometer start marking miles and other warning lights are on. Battery is a bosch 7 months old. Sent from my iPhone using Tapatalk
  3. Loren where is the ABS pump located on my 2006 Cayenne V6? Thanks for your help! Sent from my iPhone using Tapatalk
  4. Hi need help with the location of the ABS pump of a 2006 cayenne V6. TIA Sent from my iPhone using Tapatalk
  5. Thanks Loren when I replaced the hose the part in circled in red was not included. Sent from my iPhone using Tapatalk
  6. I know the turbo has them on top of the motor. And I search my V6 an saw something that looks like the pump under the passenger headlight. Just want to confirm. Also I don't have the location of the relay search near the brake fluid reservoir but they are a few dont know which one belongs to the pump. Thanks again!! Sent from my iPhone using Tapatalk
  7. Thanks a lot Loren one last question what is the part number of the plastic part with screws the hose attach to?(motor) Sent from my iPhone using Tapatalk
  8. Thanks Loren where is the pump and relay located? My cayenne is a V6 2006 Sent from my iPhone using Tapatalk
  9. 2006 Cayenne V6 Sent from my iPhone using Tapatalk
  10. Hi Loren hope you are fine, any help with the part number for the part the expansion tank hose attach to? Sent from my iPhone using Tapatalk
  11. Hi Loren, been generating this code on my 2006 V6 Cayenne. Where is this pump located? Any relay or fuse Incan check? Thanks Sent from my iPhone using Tapatalk
  12. Is this normal? I replace the expansion tank hose a year ago? Thanks for your help! Sent from my iPhone using Tapatalk
  13. Just checked I think is the brake booster vacuum line. Need to remove the wipers and plastic parts to trace the hose. Any DIY for the wiper removal?
  14. The hose is a vacuum one it connects to the venturi thats on the engine. It goes behind the firewall to the drivers side.
  15. Hi Loren I need the part number of the hose that goes through the firewall. Mine is broken tried to cut the broken part but it continues to break. the other side of the hose connects to the plastic venturi in the engine. se attached pictures. thanks!!!
  16. Did not shift to the next gear. Pushed the gas and did not accelerate. Like it was on neutral.
  17. The battery is year and a half old, no error codes , the problem is when the transmission is in drive.
  18. i have a 2006 Cayenne V6 with 131k on the odometer. Never had problems with the transmission. Today I drive 60 miles an of a sudden the transmission jerks and went blank. Stopped check everything no leaks anything, continue driving and it starts doing the same thing it does not engage third gear. I arrived home driving in manual. checked the transmission control module and it looks fine. What can it be? Let sit the cayenne for about three hours and drive it. the transmission shifts normal. Only thing I did different was to change tires last night they are the same size as before. Please help can I drive it back home?
  19. Hi my hood handle is missing on my cayenne. I need the part number to replace it is black interior. thanks
