MDA0303
    2002 Porsche Boxster (15,000 miles)
MDA0303's Achievements
  1. I have a porsche rep wheel that im trying to fit. i took care of the fronts. The rear tire is 19x11 with a 58mm offset. What size spacer will i need? I want to keep it as close to the shock as possible to eliminate too much poke. I fit these same wheels on a boxster with a 23mm spacer in the rear.
  2. I need a 20mm spacer to clear the strut in the rear. does anyone make one? if not, what kind of shop may be able to make me one?
  3. They are these in 19in. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=230345627241
  4. Im trying fit new wheels on my 986. what size spacer would i need for wheels with those dimensions?
  5. I have an 02 boxster with very low miles. I take very good care of it. It has seen the track a few times. Iv also had it sideways a couple times recently. All of a sudden now the PSM isnt turning off. When the wheels have any spin the power cuts out. And the red indicator light isnt turning on to show it is 'off' Im a little new to the porsche forums. And I have searched for this issue. No luck. Any help would be great or if you can point me in the right direction. thanks
  6. And i have the VAG-com obdII software on my laptop for my VW. one of the best things i have bought for it. I might start looking into the porsche software.
  7. haha wow. We bought the car new in 2002. Amazingly it never got driven. The only problems that is has it traction control is stuck in the ON position. (probably from me putting it sideways a couple times) and the window issue im going to do surgery tomorrow on it and let you guys know what i find out. thanks for everything.
  8. thank you that is great information. I gotten away without the bentley manual with the VW but this could be my reason to pick one up. i do not hear the motor try to work at all. all i can hear is a click from inside the door when i push the button. im going to start trying to do some research now. anymore input from other members would be great.
  9. Its a 2002 boxster. Stored its whole life. Only has 16,000 miles on it. But i cant get the window to go up. When I push the button all i hear is a click coming from the door. I am new to this forum.. but i have over 10,000 posts on vwvortex for my second car. can you please tell me if you have had experience with this issue. any quick ways to fix. how much the part will run me. and where i should look to get it. thank you, mike
