Christa
Everything posted by Christa
  1. sorry that in you site dont work :( i found this one wich works for sure . i found right now searching :) http://login.dealerskins.com/SiteSpecific/...frameset_en.htm
  2. Another question please do you know a link where i may download the PDF part catalogue of 968 many thanks
  3. many thanks loren but in my european boxster the part inside dont have the 01c ath the end dont know why i will check tommorow at my dealer
  4. Hi the guy who clean my boxster put a sparay and destroy my batwing the destroyed one has the 996.552.335.00 number i am not sure i think it is black is it right? many thanks my center console i think it is graphite black is it right too ?it's a 1999 2,5 boxster savanah beige inside and midnight blue outside thanks again
  5. 93 octane are very low for best performance ,i use 100 octane BP ultimate the car works great with 100 and go slow with 95 or 98 . do you know if your injactors need cleaning in 30000miles means about 60.000 km?
  6. i would like to know if i keep the catalisators and just put "octapus" headers my car will be out of normal value emissions? the consumption will be higher? thank you christa
  7. thank you very much. you were right it was a tube out of the pump why they did not put a ring there to avoid these problems?????
  8. Hi guys long time to talk :) i today i left my washer system be empty of water and when i try to cleen my glass water finished suddenly. after an hour i put water in the water reservoir but when i try to clean glass water dont flow from the nozzles but come out of the drivers side wheel. it come out of the inside thole plastic protector between body and wheel i think maybe a rubber come out from the pressure between the pump and the washing nozzle it is not inside the frond hood because i open the hood and remove the covers and unlucky i think it is in the left-side fender liner can i fix it? please help
  9. thank you guys for the part numbers off my rubber and plastic screws and it is not he it is she Christa ... :) you dont believe women know some mechanical issues ... :)
  10. no no in the hood i remove from the passegers side in front of the seat under the console the black foamy cover to see the motor of the flap . this foamy cover holded by 2 plastic small screws with "big head" this screw screws on the plastic climate box where inside is the ventilalation rotor of the passengers side foot heating
  11. in the heater mechanism plastic screws with big head :)
  12. i own a 99 boxster after a long drive i listen to this noises makes me believe that "a rubber sound" something like this like 2 rubbers touch and make noise themselfs
  13. hi when i remove the plastic cover uppper from the air cabin filter removing the screw the rubber with the screw inside wich fix this cover braked i mean when i try to screw again the the ring come out of the rubber and the cover placed without the screw could tight i need the part number of this rubber where the screw screwed if you could give me for the rubber of the other drivers side too because i thin this is old too thanks christa i need too the plastic screws wich 2 of them keep the passengers side foam cover down in passengers foots down from the ventilation "the black foam cover" keeped in place
  14. i examine under the passengers side console and i found that the motor wich open and close the flap the mechanical parts after the motor drive the parts wich move the flap make the noise for a few seconds when the flap open or close. i looks like the flap opens and after the motor try to run for 5 seconds more and the flap is already opened and the motor forced more time to open. i put some lubrricant and the noise of the more trial to open stoped but is noisy this opening and closing of the flap. it can be listened inside the cabin.
  15. hi Christa from greece i own a 1999 2.5 boxster last month when i stop my climate and when i open again i listen to a noisy opening of the "flap" in passengers side of the car the motor when the flap is open or close make the mechanism make a "tac tac" noise why this is happening? thank you very much christa
