zgdanska
Everything posted by zgdanska
  1. why this two are not in the manual ?
  2. hmmm , this is from the manual above 50F 15w40 10w40 20w50 15w40 15w50 20w40 below 50F 15w40 10w40 10w30 5w30 below 14F 10w30 5w30 i don't see any 0w40 5w50 . Any help with that ? or maybe the manual is outdated ??
  3. Thanks Just found the cd with the manual and looks like they overfill the engine by almost 3/4 liter .(i ran the car for 20 min , then park in garage and waited 5 min ) I will go to them change the oil to 0/40 and fill only with 8 cans for now . :renntech: ps To Loren I have 53000 miles on this car . 2002 cabrio 911 996 3.6 non turbo . What will be the best choice of oil ????? Thank You always for your input.
  4. what is the proper procedure to check the oil level ? thank you :renntech: ps Just did my oil change at jiffy lube and they put mobile 1 5w-30 into the engine . I am in troubles ?????
  5. when i check the oil level what should i trust ? The dip stick or the oil sensor that is giving me the data on my dash (10 bars)?
  6. new relay and new headlight switch-- all up ! Thanks Loren :renntech:
  7. i change all 3 oil separators. Everything perfect . Just some leftovers from my pipes . Thanks Loren :renntech:
  8. Thanks Again . :renntech: You are the man
  9. Do you have the part number for the aos that is on the top of the engine ? ps.Thank you , thank you , thank you for your help
  10. Hello Loren why they are two oil seperators ? I one for left and the other for right cylinders ????
  11. There is no oil in the coolant.
  12. did you had the same problem "cocmosC4S" ??? i look into your post . You had some smoke on start up only ? :renntech:
  13. cooland level is normal , but i will check for oil in cooland .
  14. there are no bad codes , now this engine runs fine . I have no idea what is it ?
  15. Hello Loren Maybe some advise from you?
  16. Ok . We add only a one quart of oil , removed the pipes and started the motor again . Looks like everything is fine now . It was burning the oil only in right head. Any idea ? . Coolant did not leak .
  17. I took the car for a ride this morning and while I was doing about 65 I started to see white smoke in a rear of my car . I pulled over , stoped the engine . There was a huge white cloud of smoke coming out left muffler . I checked the oil and it was almost empty . The oil gauge was reading only 1.5 . The engine still starts so is not blown but any idea what it may be ???? ps. after i tow the car i got back to my garage i noticed a few oil spots on the concrete. Thanks for any input before I go to the repair shop. Daniel 2002 911 cabrio 3.6L
  18. thanks for the tip ! I will cancel the order and call sunset first thing tuesday morning. :renntech:
  19. well i also have the 05 cayenne s and when press the psm button it goes like a rocket . Just looking for some modes .
  20. Thanks Loren for your help. :cheers: I just order a new switch from pelican parts ---113$ and 6$ for the relay . ps. My 911 is with auto trany, but is there a way so can change the way that my trany shifts . The way it works now it starts from 2nd gear and it goes very quickly to higher gears . It is good for mpg`s but not to sporty . I can use the tiptronic but i don't want to . Also I don't have the psm button . any ideas ? Looks like you know the stuff.
  21. and yes they turned on. So looks like i have a bad head light switch .
  22. i am reading only 5.6 volt at fuse 9 and 10 .
