mike424u
Everything posted by mike424u
  1. Anyone found out any info on replacing the CDR30 on Gen 2 09 boxster or cayman. I have tried to find anyone that might be able to help. The CDR30 has a new type connector, Quadlock connection. So far no aftermarket wiring harness to connect up an after market system. Im still looking if you find any info let me no ASAP. I did here that in ASIA the PCM system has to be removed as it doesnt work there so guess the ASIA market will have a wiring harness to connect up an after market system If you no anyone that has info on this let me no ASAP If i find any further info I will keep it posted. Thanks mike
  2. Looked at that one but its the wrong type, 2006 porsche seem to have some thing called a FAKRA type fitting, either that or Hirschman on the back of the becker CDR24, I have found a few but just need to confirm which one is the correct one now then place an order. Thanks anyways. mike
  3. Does any no were I can get hold of a antenna adaptor to go from the standard porche fitting which is a very small fitting to a standard iso type normal euro type. I think the porsche fitting is motorola ? I found loads in the USA on crutchfield but not found any on ebay in the Uk. Any ideas. Thanks mike
