bbailey204
Everything posted by bbailey204
  1. I just had my slave cylinder replaced and while at the shop having the mechanic trace an oil leak, the clutch was depressed and remained. He stated it was the master cylinder. Should the slave and master be replaced at the same time also? Thanks Bill Well after two weeks and a replacement of the slave and Master cylinders I now need a clutch because I am told it is the pressure plate in the clutch which is causing the slave cylinder to blow seals......Is this true??....it is becoming a very expensive oil leak.....
  2. Has anyone heard of an Air Intake manifold seal leak which may have caused a CEL? Also took my 99 Boxster with 50K miles to a local shop that specializes on Porsche. They did a smoke test and internal camera and determined that the Air Intake Manifold had seal leaks...Also the Oil filler hose was leaking oil. My question is I have never heard of anyone else posted here with this problem. I thi
