ci_redbaron
Everything posted by ci_redbaron
  1. Thanks Loren for the electrical diagram. Has anyone replaced a control unit for a convertible top for a 1997 993 or similar vehicle. I am wondering if it is a plug in type of unit or if it has to be programed using the Porsche computer diagnostic system. Local dealer charged my friend ~$275 to diagnosed the problem and has quoted ~$700 for the control unit for the convertible top plus installation. It can be bought through Sunset Porsche for $380. If it is just a plug in type of unit it should be simple to change. Anyone have any experience with 993 convertible tops? Dave T It is a plug in unit under dash on driver side. pia to get to though. I install tops in N.J. and also repair top frames and trouble shoot complete power top. Before buying it I want to make sure that I can get at it and replace it. Does any portion of the dash need to be removed? Right or left side of the drivers side. Could you give me a description of the size and shape. Also should the battery be disconnected prior to installation? Any other advice is appreciated. Thanks in advance. Dave T Dave I have a '97 carrera and have a problem with the convertable top. It doesn't work at all. Did replacing the controller fix your problem? Was it easy to replace? thanks -jon
