uwti
Everything posted by uwti
  1. Is it possible to purchase the rotor hats and retaining hardware seperate from the carbon ceramic rotor? Does anyone have a source? Thanks,
  2. Did some more digging the wheel hub on my 02 turbo is part number 99734160501 (preceeded by 986-331-605-20; 996-341-605-91) which fits 02 turbo and 04 gt3, the only differnce is the gt3 has a spacer part number 99736160590. The big difference is the carrier is a total different design, bolt holes accomodate the same 6 piston setup. But. the positioning on the upright may be a bit different which explains why differnt rotor part number (differnce is the rotor hats). So my question is the hat deeper shallower, is it something that can I can use a space plate to move out? or would it need moving in? if the later I may have a problem.
  3. Yes, will be on street most of the time! took me 10 years to drive it 13K miles! so I think they will last a long time! did go to the track one time and deystroyed a good set of tires! The rotors are off a gt3 2004 and are the 350mm type, 997 for sure won't work. What might be helpful is if anyone has a picture of a 2004 gt3 front wheel hub. beacuse it's the only place that there may be an issue. I measured the eyes of the bolt holes (142mm, or just under 5 5/8 inches) and the 04 gt3 PCCB 6 piston calipers will bolt up to the upright carrier, I may need longer bolts? ? so the hub is the bottom line? maybe an issue of simply needing shims? I won't know until I get all the parts together I guess.
  4. Ok, do you know the issue? is it the caliper mount or the way the rotor seats on the wheel hub thats the issue? Thanks,
  5. I wanted to upgrade my 02 turbo to carbon ceramic brake system, and found a good deal on some like new 03 GT3 PCCB rotors. I realize that I need a front 6 piston calipers to run these and have a line on getting those as well. But now I am told the these may not work without modification of my existing hub, carrier etc? the guy I spoke says the turbo has different part numbers than the GT2 and GT3 and there may be fit issues with rotor rubbing either to the outside or inside pad (he did not specify). Does anyone know anything about this? if so is there a reasonable solution, shims etc that can be used to solve? Here are the front part numbers for the rotors, my car a stock 2002 996 turbo: Carbon ceramic rotor part numbers. 996.351.031.92 Front Left 996.351.032.92 Front Right
  6. Thanks, yes that makes sense, but do you know if the turbos are oiled by the engine oil, or are they on a system of their own that requires oil to be added in a seperate location? Thanks, Yes, it is engine oil fed through pipes. Here is the 996TT Oil Circuit (item 14 is the turbos) Thanks for the info, I also called the dealer to ask about draining the turbos, they said not to mess with them, that you are going to have nothing but problems! they did not specify exactly why, but warned me that it was not needed. I am left wondering what problems I would encounter?
  7. Thanks, yes that makes sense, but do you know if the turbos are oiled by the engine oil, or are they on a system of their own that requires oil to be added in a seperate location? Thanks,
  8. I would try and get the car at the best possible price! (assuming it is clean) 20K or less would be good! than contact a porsche dismanteler! there are many of these cars around that have been wrecked with good engines! You shoule be able to pick up a good used engine for about 10-12K (less turbos, ECU etc) or 15-20K complete, but be careful and ask alot of questions before buying, warrantly etc?
  9. Gonna change the oil in my 02 996 turbo, I had heard that it is a good idea to also drain the turbos?? I have located the oil filter and the engine oil plug, but I still cannot find the oil tank drain plug, can someone describe where this is located? Also the turbos drain plugs I have found them, but!! how are the turbos fed oil? is it via the same system the engine is on or do I need to fill the oil for the turbos in a seperate filler, I am assuming they are fed via the engine oil but I want to be sure before draining them?
