NeedHelpPlease
Everything posted by NeedHelpPlease
  1. Milage? Did happen all the sudden or over time? (as in getting worse). Regards, PK 98,000 miles.. Thanks again for your help
  2. Is the wine speed dependant or Rpm dependant? Cold, hot, all the time? Leaking? All gears? Regards, PK The wine is speed dependant but you can hear it even when you are driving slow. Hot or cold makes no diff. No leaking. And it makes noise in all gears but it gets louder the faster you go. Thanks for the help.
  3. Went to change the fluid in a 6 spd and took out the top bolt on the drivers side of which now i know is the wrong fill bolt now i cant get the bolt back in what is the fix.... we only had 2 choices and we took out the 13mm hex not the allen bolt thanks so much... Please need to drive the car to work tomorrow...
