mungwi
Everything posted by mungwi
  1. Thanks for the quick reply, that was fast! Couple more questions about the parts. The plastic/rubber pieces seem like wear items, good idea to order new ones instead of reusing them? so far i can identify the following parts i'll order and replace 996 333 105 03 rear add'l springs (bump stops) 996 343 301 02 front add'l springs (bump stops) 996 333 107 00 rear stop plates 996 343 107 13 front stop plates 996 333 504 00 ring 996 343 523 00 support ring unsure about the following parts 996 343 501 00 angular contact bearing 996 343 015 04 supporting mount lastly, i noticed there's some light rusting on the bottom of the front springs, is this something to be concerned about or is it common and not to worry?
  2. I have a 01 turbo coupe and just got a used set of ROW M030 suspension parts, but I'm unsure if they're the right parts for my car. The struts' part numbers seem to indicate they're for 04+ coupes (rear strut 996.333.051.36). On the parts catalogue (Great Britain, E_996T_KATALOG.pdf) I see there's a different part for 01-03 models, 996.333.051.17, what are the differences, if any? If these are the right struts then I can go ahead and send them to bilstein to rebuild? I think the PO said he took them off his 02 turbo coupe, I was hoping the struts are the same throughout all 996 turbo years.
