chema
Everything posted by chema
  1. i have not done it on 987 (only on 996 and 955). plugs and form factor were the same - the only difference is marking on the glass (E vs DOT) and different shape light beam (you will not notice the difference). it would be too expensive for Porsche to have too many differences between regional versions so i guess with 99% certainty you can swap one for the other Thanks for your answer!
  2. I've heard that the USA xenon headlighs are different than the european ones. I've imported a USA boxster 987 into Europe, and I need to replace one headligh, anyone knows if I can use the european model in a USA vehicle? Thanks! Chema.
  3. Hello, I've the airbag light on the instrument panel on. I've tried reset it of with Durametric, but it didn't work. Durametric reported this errors on airbag: 80F9 unknow error: 33017 8016 DVD unit C152 Meldung timeout PSM Steuergeraet C140 Meldung timeout Kombi Steuergeraet 8055 AWS-LIN no communication 8012 Alimentación de tensión valor límite no alcanzado ------------------------- Any help? Thanks!
  4. Great manuals, thanks! Chema
  5. Thanks for your answer, I'll try! Chema
  6. Hello, I've to replace a buble light for in the instrument pannel of a 987 boxster, anyone knows how to remove it? I've found information for a 986 but it is completly different. Thanks!
