cmalana
    Plano, TX
    2000 996 C2 Cab
    Mazda Spec RX-7 Race Car (SCCA)
    1996 993 Twin Turbo
cmalana's Achievements
  1. I just spent some time this weekend completing the hardwire install for my Valentine One. Thought I'd share what I did to help out some other people who will attempt this project in the future. Tools to use: 1.) Wire stripper/wire cutter/crimper 2.) Tie wraps 3.) Blade Fuse Tap (optional) 4.) 10mm box wrench 5.) Credit card or some other plastic card 6.) multi-tester/voltmeter Installation: 1.) Decide where you would like to put the V1 unit. I do not have a remote display so I didn't have to worry about that portion of the install. I have decided to install mine on the upper passenger side windshield, just above and to the right of the rear view mirror. The reason I decided on that location is that I can flip down my passenger-side visor and most of the lights are hidden from the rear, but I can still see them from driver's seat. I don't think the visor has a high metal content so rear radar detection shouldn't be diminished (rear laser will not be detected though, but I don't worry about rear laser where i live). 2.) Decide where you would get power. I had to find something that was switched on and off with the ignition and decided to use the heated seats fuse. I bought a blade fuse tap which you can buy at a Radio Shack. This goes over one of the terminals of a blade fuse and gives you an easy connector to attach to. You can also use the included wire tap to tap into one of the wires. I'm not much for wire taps...so I didn't go through this (just personal preference). I ended up using the wire stripper to change the the male connector attached to the included hardwire kit power lead to a female connector so it attaches to the blade fuse tap nicely. test your new crimp by pulling slightly to make sure it is securely attached if you do change the terminal. Using a multimeter or voltmeter helps with figuring out where to get power. 3.) Decide where you are going to get ground. In my case, I found a bolt in the center console area (10mm) that was easy to get to after popping off the lower carpeted trim on the driver's side by pulling the side towards the front of car. The included V1 kit has a terminal that's too small for that bolt so I replaced it with a larger U-shape terminal. I think the included one can work also, but I had these bigger terminals lying around. I could've tried to find ground somewhere closer to the fuse box but since I had enough wire and it wasn't really in the way, I ran it this way. Check crimps! 4.) Plan how to run the wires. I decided to run the wires across the top of windshield (really easy to hide wires there), and then down the driver side A pillar, then down to the fuse box. I used a credit card (suggested by a friend) to help insert the wire between trim pieces and the glass. This was surprisingly easy and the wires are all hidden except for a about a 2-inch piece that attaches to the detector. Just put the wire next to the trim and use the card to push it in, and it's gone from sight! 5.) Test. Don't tidy up until you've tested it and it works. Mine involved just making sure the V1 turned on and off with the ignition. 6.) Tie wrap to get wires out of the way. For my install, i had to make sure that the wires running between fuse box and center console area were hidden and out of the way. 7.) Tidy up (put back trim pieces and fuse cover) and admire your work! This took me something like 2 hours...which included several breaks, and also a lot of firsts...I have never popped trim pieces on this car so I didn't quite know where to pull (don't want to break any clips). I have also never installed a car stereo or anything like that. I've never hard-wired a V1 before... If I had to do it again, it wouldn't even take 30-45 minutes. Was even thinking of removing visors to get to A-pillar, so this included a trip to a friend's house nearby to borrow torx wrenches, which I didn't use since I didn't have to remove trim. By the way, remember that there is an inline fuse so if later on, the radar detector doesn't have power, i'd check the fuse first. I marked where the inline fuse was by using brightly colored tie-wraps (and left it accessible without having to pop panels). Also, if you don't have the radio code, don't disconnect the battery or pull the radio fuse! Hope this helps with someone's install. It's so much nicer not to have the cigarette lighter plug dangling from the V1. Also, with visor down, it's harder to see the radar detector because the visor makes the detector less visible (it blends in with visor). Carlo
  2. Used to happen with my 993 twin turbo when I had monoballs...lubrication was the fix for that particular instance. Carlo
  3. I just registered with the forum and I want to say thanks to Loren for the instructions on removing the stock exhaust. Only problem I had was finding those 3 bolts that hold the exhaust bracket, but now that I know where they are, it won't take me close to 2 hours like it did this time. I am not at all mechanically inclined so it took me a bit longer than the norm. I say an hour next time. Fabspeed exhaust sounds great. Even at idle, the car sounds throatier, and when at wide open throttle at the upper rpm's, car sounds awesome! I especially like the fact that I can still soft-pedal it and have it be quiet, yet when I gun it, it sounds like a sports car. Some friends encouraged me to do this upgrade and I'm glad I listened...since I initially thought I'd be keeping the stock exhaust. Biggest deal for me was that I was having trouble hearing the engine rev when I blip the throttle on downshifts...now I can't miss it. Looking forward to my next DIY project - most probably the garage door opener mod, which I may do along with the spoiler switch mod since I have a cab and both buttons will end up on the left center console. Might as well do it all at once. Great forum! Carlo 2000 C2 Cab
  4. hi! I just joined this forum and it's great catching up. I also have just recently purchased a used hardtop and would like a copy of that TSB. Just want to make sure that at least the simple things have been looked at since there is definitely some noise. Of course, it is a hardtop... Thanks. Carlo
