Tal Isbell
Tal Isbell's Achievements
  1. The above post on two-sided tape got me thinking so I gave the remaining internal part of the handbrake a good look with a flashlight to see how the button would attach with an adhesive. The remaining part is best described as looking somewhat like an I Beam. So I pulled out some two part epoxy putty (technically EP400 from Home Depot) and kneaded up an amount about the size of two pencil erasers and placed it in the tip of the button then rolled up a real small "string" of it and put in the notch on the bottom of the button. While I do no know exactly how much adhesive is needed, the consistency of the expoy putty allowed me to get comfortable that unless I put too much in there, it would not leak (or squeeze) out of the button and adhere something I wanted to move freely. I let it cure overnight and this morning the button feels firmly attached. I am not going to do something silly like pull on it to see if it will come off, but my test of a quick pull on the handbrake without "covering" the button with my thumb resutled in the button staying in place rather than it popping off as it did before, so I feel pretty good about the solution. Thanks for the suggesstion of glue and tape. I kept thinking that there was some notch or interference fit that would solve the problem. Did not think about the simple solution. Tal
  2. Any idea on the ideal adhesive (and amount of adhesive)? My gut would be a good two-part epoxy, but having not seen what the button needs to be adhered to, I am a little concerned about putting too much into the button and having it overflor and freeze up the mechanism. Anyone done this before? Tal
