Elliottc26
Everything posted by Elliottc26
  1. May be a good idea to get your battery tested???
  2. Ah, ok thanks...will have a look...
  3. I had this problem too...airbag light on...ended costing me £350 (approx $700) to replace the airbag ECU...fixed it!
  4. I have a Boxster 3.2S, Petrol, 6 Speed, Petrol, 2000 (UK) and have had problems for the past few months. One problem was the MAF. The car was misfiring, so, I disconnected MAF and misfiring stopped. I replaced the MAF today with a new one. Now, the engine idles between 600 - 800 RPM (needle bounces), have had a load of white smoke pour from exhaust (but temp today was -1.5 C!!). I took it around the block and engine stalls when returning to idle with clutch depressed and on my return I found oil on the rear bumper (black). The CEL light remians on constant and doesn't flash. If anyone has any ideas, please please please would you kindly let me know?
  5. Hi, I have a 3.2S Boxster (2000) and am also having MAF problems...is your engine misfiring? Mine was doing that, so, I disconnected the MAF and the misfiring stopped. I replaced the MAF with a new one today and now the engine idles between 600 - 800 RPM (needle bounces between) and I have found oil on the rear bumper!! The car stalls often when returning to idle from speed; but the power goes on smooth and no misfiring!! I am at my wits end...also the exhaust gases smell different. I think you can clear the CEL by disconnecting the battery (via negative) for a few seconds to get new codes if it comes on again. I may try that then get it tested...(not forgetting radio code!!)...
