mikek
Everything posted by mikek
  1. These postings apply to switched power (as does the CDR23 pin out). I was looking for the signal that turns on the backlighting of a gauge, switch, or in the case of a radio, its backlighting when the light switch is turned on.
  2. In reviewing the wiring diagram for the CDR23 with MOST (2004 996 C2), I failed to find the terminal for illumination. What color combo of wire should I be looking for? (I like the new site layout, search function is much improved)
  3. I'm in the process of installing an after-market HU/Amp in my '04 996 C2 with the MOST CDR23 set up (Pioneer P710/Infinity 5350/fusion speakers). Looking at the pdf of the pin out for the 23, is A4 "switched" and is A5 a low amp circuit that turns an antenna amp on? If so, I guess I splice A5 to both the new amp and the antenna amp. Thx
  4. will do. Thanks
  5. Just been told by the local tire guy that my rear wheel is bent. I have the 18" Carrera wheels, option M411, tire size 285/30R18 do I have the 11 or 10" wheels? Can't seem to wade through all the posts even with a restricted search. Thanks
