valcax
Everything posted by valcax
  1. The little screws are more for convenience...they hold the spacer to the rotor/hub. They keep the spacer in place when mounting the wheel and when removing the wheel. If you don't use the screws, then the spacer may stick to the back of the wheel or simply fall. If the spacer falls into the wheel, it could scratch or otherwise damage it. The lug bolts hold the wheel, spacer, and rotor firmly to the hub. --Brian Then I can do without screw with no problem (unless removing a wheel).... thanks Qship, now I am in calm.
  2. Today I have been mounting spacers. Impossible for me unscrew little screws on hub. I have installed spacers with no screw, but with 130Nm on longer bolts. I just hope no problem. What do you think?
  3. Do you really think Porsche publish TSB with no exhaustive checking? I really dont believe. What you say is sense but TSB says it. However, as we are in whole doubt, I have bought the complete kit with longer bolts. No concern money, only I am seeking for curiosity and learning.
  4. good job!! However I still think there is no mistake in TSBs, page 7 of both TSB is for size wheels that require longer bolts. In 18" winter tires, longer bolts are required and not in summer tires. I am not sure if I am thinking wrong but this is what TSB says!
  5. If you use 5 mm spacer (with any wheel or tire) your existing bolts will be 5 mm too shorter. This means that there will be 5 mm less thread contact to hold the wheel on. Porsche sells the 5 mm spacers with the longer (5 mm longer) bolts. I would not use the 5 mm spacers without the 5 mm longer bolts. That TSB part is for size wheels that require longer bolts. Note that correct contact to hold the wheel depends on deep throat and offset, what I mean is standard bolts can be approved to hold wheels with 5mm spacers in 225/40/18-265/35/18 but not with another. So I understand. Could you contrast to Porsche?
  6. Hi loren, pay attention to TSB, footnote 5 (only with connection with longer bolts..) IS NOT MARKED for 225/40/18 7,5 /50 265/35/18 9/52 only 2 (for boxster from MY98) and 3 (remove spacers when mounting spare wheel) ARE MARKED. I am convinced longer bolt is not required for this wheel size.
  7. Well, In mycase 5mm f/r only approved, but I have question about bolts. I understand there is no necessary to replace standard bolts for longer bolts as footnote 5 is not marked. What can you tell me?
  8. Thanks Loren, Can you tell me thickness approved? I have not clear.
  9. I want to know the spacers thickness accredited for Boxster MY99. I know 5mm is accredited cause I have seen these spacers in tequipment kit, but 17mm (for rear) is written in Owners Manual MY00. Do you know with accurate which spacers are accredited for a boxster MY99? (front and rear) wheels: front: 225/40 ZR18 7,5/50 rear: 265/35 ZR18 9/52 Best regards.
  10. In CoochasTT Car I can not see almost difference, but in BennyCga there is a visible difference... SURE BOTH ARE 5MM?
  11. What is this little silver under spacers? screws? what use? http://coochas.com/pics/5mmspacers/5mmkit.jpg
  12. Someone can tell me why porsche sells longer bolts with 5mm spacers? I have seen that until 7mm standard bolts are used, more than 7mm longer bolts. only for rise price of spacers? or any reason? I want to buy 5mm spacers with standard bolts.. any problem?
  13. :king: :king:
  14. WHERE H&R bolts? I am almost sure collars cannot be removed.
  15. The locking bolt is 996 361 057 90 and I believe the regular bolt is 996 361 203 90. ed any set of longer bolts available?
  16. PArt number of longer bolts? (red)
  17. when replacing pcm navi unit, display ask for CODE NAVI, Should I introduce the same I have in my old unit? or there is to introduce a new code which is sold with navi unit? In case not have this new code... can I call a Porsche Center? Best regards!
  18. I want to update to pcm 16 bits. Only necessary replacing cd reader, and update to version 5.43 with a update disc. WRONG? :( My actual pcm is 996.642.122.00 EFR (cd reader), I have bought cd reader 996.642.122.12 EWD and I have master update disc. Any Problem? THANKS LOREN!!!
  19. I want to update my navigation unit (996.642.122.00 EFR) -boxster MY99- 996.642.122.03 EFR and 996.642.122.12 EWD Just the same part number? any difference? I need to know ... Can I use any of them with no problem?
  20. I have a problem I just hope you can help me. The Navigation Unit PCM1 has a code and the PCM display has other code. But, where is stored the code? one in the navi unit and other in display?, or is stored in the car memory ? I want to replace navi unit but seller has not code card, he says code is the same I have in my old navi unit. but I dont see clear because I have seen new pcm navi unit with a grey code card. HELP!!!
  21. :oops: :oops: :oops:
  22. I would like to know this Porsche DVD Navigation fits in a boxster 986 2.5 MY99 Part Number?
  23. Today the black plastic under left exterior mirror has fallen down. Now I have to put it on again but I dont know how, can you help me? Thìs is the piece...
  24. when key is removed, digital display stays light on. When doors get closed, then it is turned off.
  25. 986 MY99, manual transmission. Part number ?, Price? Flywheel is included? part number? price? Best regards.
