fram914
Everything posted by fram914
  1. Hi, Thanks for the reply. Yes the O ring is there. That area is bone dry. The oil is coming up the shaft into the dist. I'm going to take it apart today and see what's inside. The parts book seems to show two bushings and some other unidentified part between them. Thanks again, Fred
  2. Greetings, My problem is oil migrating up the dist shaft into the dist housing and leaking from the holes in the base of the housing. I took the dist out turned it upside down and oil ran out. The oil drips down the cam chain cover giving the indication of a leak from the cover. Is there a seal of some sort around the shaft to prevent the oil from coming up the shaft? Dist # 90160202700 Bosch. Thanks
  3. Really, I didn't know I could take it out and have it painted. Great information. Thanks
  4. Hi, My 73 s fan shroud finish is showing it age and replacing it would cost a fortune. I am aware it was not painted originally. Has anyone been able to match the color to a paint code? Thanks, Fred
