markopolo34
    jacksonville fl
    2005 cayenne turbo
markopolo34's Achievements
  1. thank's for your help, I have trouble again after cleaning the maf and the inside of the air box (where by the way found a lot of debris) ,the car ran fine for half a day, but, when I stop to get some groceries and comeback, doesn't want to run , that is, I crank the starter and he runs for 2 seconds and stops, so I do what you guys sugested and take the maf conector off ,and he start running again (thank's again for the advise) ,so here is the question ,IS IT POSSIBLE , IS THE MAF GO BAD ,TO HAVE THAT PROBLEM I MENTION BEFORE,THAT IS THE ENGINE RUNNING FOR JUST TWO SECONDS AFTER CRANKING AND GIVING THE SENSATION OF NO FUEL GOING TO THE ENGINE ,O IS JUST COINCIDENCE,SINCE THE MAF IS SUPOST TO HAVE LITLLE INFLUENCE ON THE FUEL INJECTION,ONLY MINOR ADJUSTMENT,thing is the car start and runs fine now (maf disconected),thank's again for the time you take to aswer this.
  2. hey,thank's for the aswers,I just take the maf out and clean it whith electric cleaner,check the (original)air filter and put everthing back,car runs excelent but I din't check it on the long run,and since de problem comes and goes,I don't know what to expect,because if the car start,it runs normally,like I said,he sometimes just run for 2 o 3 seconds and stop,always in a bad place of course(usually when I go to pick up some female friend,and they are not that ugly), thank's again
  3. hey guys,please help here,I have a 1997 boxter,triptronic,38 k miles.the car was running fine til one week ago,when the ce ligth go on,after I get the ligth on,sometimes the car doesn't run,that is,he runs for like 2 seconds and stops,givin the sensation of no gas geting to the engine.after triyng for a while o waiting like 1?2 a hour he start fine and run perfect,til I stop and the ting happen again.sometimes he has no problems at all.by the way,I read the codes:po102 and p 1115,maf and oxigen sensor.in case I have to clean o change the maf,where is this located? procedure?,I relly will apreciated any help thank's mark
