golinu
Everything posted by golinu
  1. Thank you Loren for your fast help. I will check my connections and will clear them ;) This is an easy first step B) Chears
  2. Would it be possible that my DME and/or throttle jacking sensor harnesses are damaged unless it happears randomly ?? I have made arround 5.000 kms between the first time I had the problem and the last time.
  3. Hi, I have exactly the same problem than you with my Boxster S from 2002. Sometimes,in high acceleration, the power move down dramatically :-( I need to stop and start the engine to clear the problem. It's now the 3rd time I have this. I have the same error code P1501 (and P1505 / P1508). Did you finally found the problem ??? Does your Boxster fully original ? I mean did you change something like the exhaust ? Did you had issues with the Lambda ? Thanks in advance to share with me your experience ! Cheers. Christophe from Toulouse (France)
