andy1977
Everything posted by andy1977
  1. had warning light with "brake dispropotioning" and when it was plugged into the fault codes pointed towards the pressure sensor as it gave crazy readings and the pressure would jump about. I changed the brake pressure sensor with no joy, have now swapped the abs pump and module and it has solved the problem, my new problem is the the steering angle sensor needs set, does anyone know how to calabarate this ???
  2. hi thanks for the reply the hydraulic pump is 955 355 955 04 the other number is for the control unit attached to the pump
  3. What does the letter at the end of this part number mean ??? I have been looking for a replacement part 7LO 907 379 C which is the abs module, I have found a few on line but they all have diffrent letters at the end. I was told that they are all the same, they all have a vw badge on them would 7LO 907 379 F which is the one for a 3.2 cayenne do the job in my 4.5 s ? hope someone can help me i'm pulling my hair out ! why do they make it so complicated
