zft325
Everything posted by zft325
  1. i would if i could loren but the problem here in the Philippines is that its very limited. we have a dealer here but they dont accept cars that are not bought out of there showroom. the shop i went to has the PIWIS is there a thread here that has instructions on how to properly bleed the system using PIWIS or only accredited porsche shops has that? i dont want to burn all that money because its very expensive here for some service. I understand what you are suggesting but im just hoping that with the experience of experts like you i can work hand in hand with the mechs of the shop that has the PIWIS. (if ever they dont know the proper procedure). again thanks for your advice loren.
  2. you mean properly bleed the unit? is it possible to just change the electronic part or i need to change the entire abs pump with module? i can see screws beside the pump but i dont know if i can just inter change them. your input is much appreciated
  3. sorry how can i tell? i can send you the vin number. ive been looking in ebay and im confused about the traction control and the (option M224) or locking diff (option M222. need expert help from you
  4. Hi loren, sorry i wasnt looking at the codes. but i think its 4250 or 4272 not sure. the only thing i saw is the hydraulic control module. they tried to erase the fault but it kept on coming back. now have few questions? i saw some parts on ebay but im wondering how do i tell that mine has traction control which some sellers specify on their parts. and would you know the part number that i can follow for my unit sir? i think i posted this on the part number thread. thanks for your help.
  5. Hi any of you know the part number of the hydraulic control module with abs pump for my 2001 boxster s? thanks
  6. ok just an update. my problem is the hydrolic control unit of the abs. according to the diagnostics.
  7. Hello, anyone knows what might be the problem on my boxster s, the manual mode of the tranny doesnt work both on the steering and on the shifter. btw does it have anything to do with the 3 lights on the dash( psm off,abs,and brake pad wear indicator) i still havent replaced the brake sensor as loren's advise. thanks
  8. ok ill check cps sensor. he did try to get codes for it but the scanner doesnt throw any
  9. ok i will check tom. let you know the results.
  10. Hi my friends boxster acts up when the engine reaches the normal temp. it dies after that. when he tries to crank it it doesnt wana start. he has to wait for it to be cold again and then after that its ok again. can this be the same as the problem on mercedes Crank position sensor? thanks
  11. nope no mech and no major travel. its just mostly around the city. engine is running perfectly normal. no peculiar changes on the driving. coonection on the maf can cause that? even if engine is running normal? thanks
  12. yes sir, just checked
  13. Hi loren the switch seems to be working fine, or is there any other way that it may be a problem? appreciate your input on this. just worried about travelling today. thanks
  14. Hi can i get some info on whats wrong with my car. i have 3 warning lights on (pgm off,abs,and the brake pad indicator beside it) will appreciate the help guys. thanks
  15. thanks ill try that today.
  16. hi loren, thanks for the fast reply. yes i have a problem with the central lock. i cant operate my locks when im inside and when the car is running. but i usually get 2 beeps only after locking the doors when i park. its just recently that i get another beep. sorry for my lack of understanding on the beep sounds but what do you mean by alarm zones? how do i check on that sir? thanks
  17. hi, just wondering what is that beep sound after that 2 beeps when i press the lock button on the remote? just after the door are lock maybe 5 seconds after another single beep will sound? is this a warning of some sort? thanks for any input
  18. thanks to you both richard and loren :thankyou:
  19. Hi loren. sorry got confused on your msg. on the diagram its LH side part. on your part number is for Rh. can you pls give me the left hand side (driver side) pls sir. thanks alot
  20. thanks richard. now i can order this part. you have any idea how much would this cost?
  21. any updates on this problem? im beginning to feel that i need to replace the tranny already
  22. Hi , any of you know the part number for the broken underside plastic (not sure with the name) . ive attached a picture of the broken part. thanks in advance.
  23. hi any of you have the part number for this model? 2001 boxster s tiptronic tranny? thanks
  24. Hi guys, its been awhile since ive posted anything here but guess what?! i still have the same problem. still no solution. i guess the best next step really is to change the tranny on my car. im still using the car as my daily driver and its been slipping like before. and now i noticed that when you put it on 1st gear and in an incline position(going up) from stop. I cant seem to drive the car as smooth as it should be and it feels like the tires are slipping but when i checked the wheels its not even moving. what do you think guys?
