aerogianni
    99 boxster 00 landrover discovery 96 bmw 328is
aerogianni's Achievements
  1. :welcome: P1123 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Lean Threshold P1125 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Lean Threshold This says that the DME thinks your mixture is too rich - and can make it lean enough. Potential causes are: - Fuel pressure too high. - Fuel injector leaking. - EVAP canister purge valve open. Make sure the MAF is functioning properly by reading the air flow at idle and at 2500 RPM no load (you will need Durametric software, a PST2 or PIWIS tester to do this). Scan for more codes - It could be a stuck EVAP purge valve. my scanners will not give me much information, i really doubt an injector problem on both banks, how could i determine a stuck evap valve
  2. I have a 99 boxster got the 1123 and 1125 codes, from the research i figured i needed a new maf. i replaced the maf and got the same codes after about 3 drive cycles. i really need help i dont know what else to check next. the bellows looked good i checked it today and also have looked for anything obvious
