whynot
Everything posted by whynot
  1. Just wanted to say thank you to everyone that responded and provide an update. Looks like the brake booster was installed incorrectly by a previous mechanic and the pin was not correctly aligned. I didn't notice this for quite some time because the car is not a daily driver and has not been taken on any extended trips until recently. The 30+ mile extended trip was sufficient to cause the brakes to engage. The mechanic replaced a few o-rings,adjusted the brake booster, and took several 30+ mile trips to see if he could reproduce the issue. Just got home and looks like we are good for now. Again, thank you to everyone that responded. http://www.renntech.org/forums/uploads/downloadedimages/report.gif' title="Report Post" alt="report.gif">
  2. I'm in the San Gabriel Valley and have it at a local mechanic in the area. The new booster corrected the problem with the brake pedal not returning.
  3. I took out my 1999 996 recently on the freeway and about 20 miles into the trip all 4 brakes engaged forcing me to limp off the freeway. No warning lights were visible on the dash (abs/psm etc). Took it to a well respected indie mechanic and he resurfaced the rotors and did a complete brake job with new fluid however the following day the brakes locked again after a short 15 mile trip. Anyone have an idea on what could be causing this behavior? Note that I had the brake booster replaced about 18 months ago because the brake pedal was not returning to it's original position. Indie didn't find anything suspect with the new brake booster. I have the following aftermarket parts installed: Dectane led rear brake lights Wheel spacers Fister exhaust Any help would be greatly appreciated as it's been at the mechanics for over a month now and he is still trying to diagnose the problem. http://www.renntech.org/forums/uploads/downloadedimages/report.gif' title="Report Post" alt="report.gif">
