pabloaviles24
    05 cayenne turbo
    06 audi s4
    02 bmw x5
pabloaviles24's Achievements
  1. Fuses are ok Fans do work but only when temp is over 210 or so
  2. Hi, I have a problem with my cayenne turbo, fans don't work until coolant reaches almost 210 degrees, they work until temp goes back a little then stop working again. But temp wont go back to normal I've read in a boxter forum that this is a low fan speed problem that is caused by a ballast resistor that goes bad. I wonder if the same problem happens with the cayenne Thanks for your help
  3. Hi Loren I'm very sorry about double posting it's my first time on the forum i would really apreciate any help thanks
  4. Hi i just bought a 05 cayenne turbo with the amp missing 1. first of all are there diferent versions of the amp or any bose amp posted on ebay will fit?. 2. The nav screen shows system error: amplifier,CD changer, satellite radio, nav system not available Are all of these items actually missing or it's just because the fiber optic circuit is open due to the amp not present 3. at last where is the cd changer mounted?, i've read that it's in the back next to the amp but there are only 3 plugs that i think are for the amp Thanks guys for your help
  5. Hi i just bought a 05 cayenne turbo with the amp missing 1. first of all are there diferent versions of the amp or any bose amp posted on ebay will fit?. 2. The nav screen shows system error: amplifier,CD changer, satellite radio, nav system not available Are all of these items actually missing or it's just because the fiber optic circuit is open due to the amp not present 3. at last where is the cd changer mounted?, i've read that it's in the back next to the amp but there are only 3 plugs that i think are for the amp Thanks guys for your help
