DIY527
Everything posted by DIY527
  1. Changed out the #1 coil today and that did the trick - no more CEL light, fault codes, or rough idling. Figured since I'd already started the process, I might as well change out the spark plugs and remaining coils. Turned out to be a good decision as the #4 coil was cracked pretty bad also. Cheers, Rob
  2. Thanks Loren- I put the car up on jacks and took a look underneath. Sure enough, didn't take long to see that I have a cracked coil. I assume the primary cause for the coil erosion likely stems from the tube depicted in the picture. Can I assume this is a water drainage tube that should probably be routed somewhere else? -Rob
  3. Just purchased an 02' C2 996 a few months ago w/36k. Car has been running great w/ no issues until today. Drove into work this morning and parked the car uneventfully. Several hours later, I went to go grab some lunch- but shortly after starting the car up and pulling out of the parking lot, the CEL came on (at aprox 15mph). Using an OBD-II code reader, the only thing that came up was a P0301 (cylinder 1 misfire). I thought maybe since I cleaned out the TB a few days ago I might have a loose hose somewhere. However, after rechecking all the connections, clearing out the code, and resetting the DME, the engine still ran rough at idle. The CEL did not come on again until I hit aprox 15MPH and then another P0301 code registered. After searching this forum, am I right to assume my next step should be to check the coil/spark plug? Any other thoughts? Thanks
