flightparties
About flightparties
  • Birthday 06/18/1973
Contact Methods
  • Website URL
    http://www.doctorporsche.com
  • Interests
    Porsche maintenance and engineering
    Majorca Balearic Islands SPAIN
    Other
    Porsche 996 Carrera 2000
    Jeep Cherokee 2.1 TD 1989
    Mercedes Benz C180K Spot Coupe '04
  • Future cars
    Porsche 997 4S
487 profile views
flightparties's Achievements
  1. I glued this nozzle in place with epoxy after adjustment to avoid losing it again
  2. Hello Friends I had this same issue, but I can solved with only 25$ yo have to buy this part 9936280720001C is the headlight washer nozzle of a 993 and you get the part that you need without spend 200$ In next post I will put some pics
  3. Thanks for your quick answer ;) Yes, brake lights works ok but I suppose that it´s a double circuit switch, so maybe can fail PSM signal circuit, but I don´t know if this is correct Do you think that could be a problem in wheel alignment? Thank you very much :renntech:
  4. Dear Loren I got this code 4440 1 week ago ( using Durametric ) when ABS & PSM Warning lights in the dash, I have a 2001 986 with Porsche approved waranty so I decided to vist my local dealer they said me that Steering Angle sensor was fault (Like durametric showed me). Then they changed the sensor and recalibrated it ( They said ) after one day, I have the same warnings lights PSM +ABS so I connected again Durametric and I´t was the same fault code 4440. Any idea? Could be also common brake swicht faillure or MAF ? Thank you very much in advance
