NoElise
    01 Boxster S
NoElise's Achievements
  1. I was hoping that would be the answer. Thanks and next time I promise to rtm first :D
  2. Hi everyone. Thanks to the help on this forum, I performed my first oil change this past weekend. Everything went well. A bit later in the day I took a reading and it read low. I put more oil in, but I guess I hadn't let it all settle because now the gauge reads one bar above the max line. Will this hurt the engine? Would you recommend doing another oil change or just allowing some of the oil to drain out by loosening the plug? Thanks.
  3. Flybye, It's the Siemens navi unit not Traffic Pro. I can grab a pic of it if that would help. Any help would be much appreciated.
  4. In that case, you will need to purchase an iPod adapter that emulates the CD changer. These are available from Dension with their iceLink product. http://icelink.densionusa.com/ <{POST_SNAPBACK}> I have the same setup as erics in my 2001 S, but have a cd changer (cdc-3) installed. Do I still need something to emulate the cd changer or can I get the wiring harness from becker and use the cd changer port?
  5. I am looking for a navi cd for an 01 (pcm1) navigation unit. I know you can call becker and get the cd for $150+s/h, but I'm hoping for a cheaper solution. I've been looking on ebay and have only been able to find 2002 cd's and from what I've read the system isn't forwards or backwards compatible. Does anyone know of a cheaper solution? TIA
