Samm
Everything posted by Samm
  1. I had to replace the oil pressure sender last year on my 02 TT too because of the same symptoms you had just mentioned. In my case, the frequency of the sender failure had increased over time. I am no expert here but would suggest to check the following before having the actual sender replaced: 1) check if the 2 electrical connections on the sender are tight and secured; and 2) check if your battery is in good condition (I suspected that my not so good battery had damaged the sender). If both of the electrical connections and battery are good, I am afraid that you may have to replace the sender. Good luck.
